• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    MtnMax700
    2012 Screen
    136 Views, 4 Replies
    02-12-2013 12:33 PM
    In the upper lefthand corner of my screen are displayed [-][TOP][2D WIREFRAME].  Have no idea what it means and how can I turn it off?
    Thxs.
    David
    Please use plain text.
    Re: 2012 Screen
    02-12-2013 12:39 PM in reply to: MtnMax700
    [-] I don't know
    [TOP]  means you are viewing the top, not the front, back, left, right or bottom.  This is normal.
    [2D WIREFRAME] refers to the style of visualisation.  This is the most common.  Options like conceptual or realistic are often used for 3d viewing.
    I don't know how to turn them off.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    neilyj
    Re: 2012 Screen
    02-12-2013 12:51 PM in reply to: MtnMax700
    This is what you get when you click the [-]
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Re: 2012 Screen
    02-12-2013 12:56 PM in reply to: MtnMax700
    Hovering the mouse over each one tells you what it is for...
    To turn it off, set VPCONTROL to OFF or 0
    However, there is a display bug in C3D2012 where your crosshairs may disappear. The only way to get them back without closing and restarting C3D is to move the mouse so the cursor crosses over that control....without the control visble, no quick fix to get the crosshairs back.
    Active Contributor
    Re: 2012 Screen
    05-13-2013 08:42 AM in reply to: Jeff_M
    I have also noticed that this crosshair bug is still present in 2013.
    David E. Henderhan, PLS
    Infrastructure Design Suite 2013
    Dell Precision T3600 - Windows 7 64-bit
    NVIDIA Quadro 600
    Intel(R) Xenon(R) CPU E5-1607 0 @ 3.00GHz 3.00GHz
    8 GB ram - Two 1TB raid
