AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
2010 C3D Etransmit leaves empty line/curve table
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello all,
When trying to etransmit a dwg from Civil 3D 2010 which has line/curve tags with tables built from them, we are getting output which has the table headers but no entries below. The cad user on the other end gets no line/curve data. The other user is on Civil 3D 2011. Any ideas? Thanks in advance![]()
Civil 3D 2010 (32)
Windows 7 Pro 64
Intel Xeon 2.8GHz
6GB
Re: 2010 C3D Etransmit leaves empty line/curve table
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would want to know if the objects being labeled are lines and curves that are part of a DataShortcut-referenced alignment and if you are checking the box for Civil 3D Dependencies in the eTransmit dialog.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the response. The aligment is live in the drawing, not a shortcut.
That being said, the civil 3d dependencies are/is checked, although it is for a surface.
Civil 3D 2010 (32)
Windows 7 Pro 64
Intel Xeon 2.8GHz
6GB
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To clarify - the surface dependency is the only dependency listed, as the alignment is live in the dwg.
Also, in the etransmit drawing, although the tables are empty, the tags still exist. The end user can rebuild the tables from the tags which are intact, we just don't know why the tables don't stay intact. The tables are empty even when opened on our civil 3d 2010 computers, including the same computer that performed the etransmit.
The file format/version is not changing. I'm hoping we're just missing something.
Any help or ideas would be greatly appreciated.
Civil 3D 2010 (32)
Windows 7 Pro 64
Intel Xeon 2.8GHz
6GB
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is the drawing open when eTransmit is issued? C3D likes to empty the tables when the drawing is saved without being open in the editor. You get the same issue when using SSM to rename Layout Tabs on unopened drawings. I had thought this problem was corrected in newer versions, but I just experienced this in C3D2012 a few weeks ago.
So, that's a long winded description of: If the drawing is not open, try it when it is.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To be honest, I've never tried to run etransmit without the drawing open. The drawing (with the alignment, tables and tags in it) is open, and is the drawing I am performing the etransmit from.
Civil 3D 2010 (32)
Windows 7 Pro 64
Intel Xeon 2.8GHz
6GB
