• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    eyescast
    Accepted Solution
    1. Quick profile on corridor section AND 2. Corridor surface Boundaries
    286 Views, 6 Replies
    10-17-2012 10:50 AM
     1.
    When a line crossing the green colored corridor section is right clicked , and  choosing the  quick profile option , no profile view is generated.Civil 3d did ask where to generate it so then the area  was clicked Still, NO profile. I spent time figuring out how to use the cube at the left bottom corner by rotating so that it shows "TOP " face. When the cube is oriented to TOP face , the drawing is oriented into a line ( like the perspective is a horizon). Initially, I was able to generate the sections (Refer. to quickProfileCorridor6).
    2. The another file shows a step to taken to do a quick profile.
    I need help so I can continue on with sample lines. Ultimately,  road section quantities need to be acquired.
    Thanks.
    Please use plain text.
    Valued Mentor
    Valued Mentor
    sjg
    Re: 1. Quick profile on corridor section AND 2. Corridor surface Boundaries
    10-17-2012 11:31 AM in reply to: eyescast
    I noticed your view cube is being showed as looking at the BACK, shouldn't that be TOP? Not sure if that might have something to do with it. Looks like your in some 3D rotation.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    Active Contributor
    eyescast
    10-17-2012 01:09 PM in reply to: sjg
    Ya, it is part of my problem description that was initially sent Here are two files , first one is turned to the top face, and the second one is turned to the front face.
    Please take note where the line is over the green corridor , the gizmo x-y-z system mode is Turned ON…. Could this be the cause of my problem.
    How do get to the gizmo mode settings?
    Valued Mentor
    Valued Mentor
    sjg
    10-17-2012 01:29 PM in reply to: eyescast
    While in model space, type VIEW, maximize Preset Views, select TOP and click Set Current, hit OK. ViewCube or "GIZMO" should read TOP. Then to reset your user coordinate system (XYZ) to World, type UCS, then hit W for world. Then draw a polyline and do a quick profile.
    Steve Goessling
    Land Consultants
    Windows 7, 64 bit
    16 GB RAM
    Nvidia Quadro 600
    Active Contributor
    eyescast
    10-21-2012 01:59 PM in reply to: eyescast
    i believe this has work , no issues on this.
    thanks
    Active Contributor
    eyescast
    10-21-2012 02:03 PM in reply to: eyescast
    Hi  was wrong; **** still needs a solution. I need to turn off the points on the assembly surface. Or change the size that's ok too. how to I change the boundaries so that assembly cross section will look it has cut and fill section?
    thanks again.
    Active Contributor
    eyescast
    10-30-2012 08:12 AM in reply to: sjg
    I was able to fix this problem thanks!
