If I edit a style point and close the window and I want to re-open thewindow of the same kind of point, I have to select the style from theSpace of tools.
Unlike commands, if I hit the right mouse button does not appear as"recent entry" or "repeat" so you can re-open the same window had closed.
This happens with any style of object, not just for points.
If we select a point, the contextual ribbon does not show a button "stylepoint" "point label style" to quickly edit the style that uses the selected point.
I understand that with the Quick Properties window, you can select the style and to "create / edit"
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
