more wishes
-> Composer reports, to create or edit our XML report template. (exist a subassembly composer but could exist reports composer).
These tools often used in the MDT program (Aplitop).
-> If I have points on the vertices, there is a routine that puts the elevation of points equal to the elevation of the vertices or updatethe elevations of the points on the elevations of the vertices. (actually, I have to change the priorities of the elements of the surface and select all points that are above the polylines .. this is a very slow process)
-> Tool to draw a mark (circle) at the intersections of polylines, feature lines, etc. .. to check the intersections graphically.
-> tool to check if there is no vertex with a point above (select the polylines or lines per layer characteristics).
In the absence of a point above the vertex, draw a mark as a circle.
-> Add breaklines to a surface from the elements of a layer. (Without having to "filters")
I organize the polylines or lines features that will break lines in layers.
-> Verify that the polylines or lines and features have been added as broken lines on a surface (Autocad Civil 3D make the mistakethat added back if they already exist as breaklines).
-> The points that have a certain code, for example, BR * or V * for bases, the code is transmitted to the point name.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
