one thing it can't do is if you are trying to specify a fixed number of pages to create on the alignment. i want 15 but it always create 20 with large overlap in between. also moving the sheet doesn't do squad. only match lines control how the plan will be created. and the matchline can't move much. if you specify a large overlap spacing it create like a million sheets. at least should be the option to add your own matchline. not computerized auto creation. good for some project but not so good for others projects.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
