command "reference elevation"
This command operates differently if you select the command from the Ribbon or selectsome points and then, with the right mouse button, you select "reference elevation"
If I have 10 points in the drawing, but select only 3 points and use the command "referenceelevation" from tape or from the menu options and then tells you the reference, such as 0,and say the new elevation, for example 5, the program adds 5 to all elevations of all points,although they were not selected.
If I do the same process but select the 3 points and pressing the right mouse button to select the command "reference elevation" then do it right only for the selected points.
Other commands, such as "surface elevations from" show command line options:
Points [All / Numbers / Group / Selection] <All>:
But the command "reference elevation" does not offer these options.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
