AutoCAD Civil 3D Wishes
Valued Mentor
fcernst
Message 1 of 4 (169 Views)
Volumes Dashboard - Subgrade Volume Capability
169 Views, 3 Replies
09-21-2012 06:34 AM
Please add a column for the user to enter a surfacing material thickness for the top surface within the Bounded Volumes areas of a parent volume surface, and have that accounted for in the parent volume surface.
This way a person could compute and monitor site subgrade volumes using the Volumes Dashboard . There is an important need for a straightforward way in the design software to compute subgrade volumes.
There is a need for civil software used in civil site work, to continuously monitor subgrade volumes for site earthwork balance, while the designer is designing the contiguous top surface (FG).
*Kudos that the Bounded Volumes update dynamically when their boundaries are grip edited.
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
tcorey
Message 2 of 4 (153 Views)
Re: Volumes Dashboard - Subgrade Volume Capability
09-25-2012 09:15 AM in reply to: fcernst
Nice idea, Fred.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Distinguished Contributor
jmatthei
Message 3 of 4 (139 Views)
10-01-2012 10:07 AM in reply to: fcernst
Holey cow yes.
It's astonishing that the program has been around this long and doesn't yet have material and subgrade capability.  And that nobody else has created some other software to compete yet.
We only have that ability in corridors, and we need it for the rest of the site.
Jeremy
el_nath
Message 4 of 4 (117 Views)
10-19-2012 01:09 PM in reply to: fcernst
Why not use a differential surface (paste proposed grade onto new subgrade surface, then raise/lower; remains dynamic to original surface)? It's not the same as a corridor model, but it does work.
For an actual model of plaza pavement layers, I've been thinking about making a subassembly that targets the proposed grade surface, where I can specify several material layers, such as pavers, aggregate, and fill. Using offsets and dividing the links, such that the top links target the proposed grade surface every 2-5 feet, depending on a user input (tesselation), I'll have a corridor that's dynamic to my design surface, which is dynamic to my site grading, and one that shows materials in sections view. Can't do that with differential surfaces.
Nathan Selles-Alvarez, P.E.
Senior Civil Engineer
You are not logged in.
Ask the Community
