AutoCAD Civil 3D Wishes (Read Only)
TIN surface modification
1 REPLY 1
rplese
451 Views, 1 Reply
I import LDT's (2006) TIN surfaces and modify them. I have trouble limiting the maximum or minimum elevation.
I have tried:
Toolspace>Properties>[surface name]>Surface Properties>Definition>Build>Definition Options
But the "Exclude elevations less than" and the "Exclude elevations greater than" are grayed out and can not be selected. Is there another route to get this done?
Bear
1 REPLY 1
fbasciano
in reply to: rplese
In Civil 3D 2013:
Under Surface Properties, Definition, Build,;set "Exclude elevations less than" to "Value" YES.
You may now set a minimum elevation>
