AutoCAD Civil 3D Wishes (Read Only)
Rotate Surface Spot Labels
8 REPLIES 8
Message 1 of 9
ctysliker
417 Views, 8 Replies
It should be possible to rotate surface spot labels about the marker point either with a rotate grip or with AutoCAD rotate command. So far all see is the ability to set fixed rotation angles in the style. Having a style for multiple fixed rotation angles seems time consuming and cumbersome.
I've read that points can be rotated with AutoCAD command or grip (C3D 2009) so should be available for all labels
Civil 3D 3008 SP2
8 REPLIES 8
Message 2 of 9
archer0599
in reply to: ctysliker
I second this! It's 2012 already and I've noticed that this has been requested for several years now. Please make it happen!
Message 3 of 9
Jeff_M
in reply to: archer0599
The following video was done in C3D2012 with a Surface Elevation Label....
VIDEO
Jeff_M, also a frequent Swamper
Message 4 of 9
troma
in reply to: Jeff_M
So this is a new feature as of 2012?
Mark Green
Working on Civil 3D in Canada
Message 5 of 9
Jeff_M
in reply to: troma
Yes, this was added in C3D2012.
Message 6 of 9
troma
in reply to: Jeff_M
Apart from rotating by hand, is it possible to select a label and set the rotation in the properties box?  That would let you select multiple labels and set the rotation for all of them all at once.
Mark Green
Message 7 of 9
archer0599
No I've tried selecting the label and there isn't any rotate option in the properties.
I use C3D2011. I'm guessing this new rotate option is only for 2012. Pooey.
Message 8 of 9
Jeff_M
in reply to: troma
Yep!
Message 9 of 9
troma
in reply to: Jeff_M
Cool Jeff that's sweet.  Thanks for sharing.  Maybe I'll get to try it out in a year or two.
Mark Green
