If I select several points of the editor of points (bay window) and clicking the right mouse button on the shortcut menupress "select" and I selected the points graphically.
The idea would be to do a reverse selection, ie if I selectpoints graphically
and show the context menu, there was an option to "select"for these points are selected in the editor points.
This could be done also for alignments and other objectswhere selected items are the same type of object.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
