• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D Wishes
    Distinguished Contributor
    Multi-Core Utilization!
    180 Views, 4 Replies
    02-22-2012 06:56 AM
    I'm thankful that there is a true 64-bit version of C3D, but now Autodesk needs to start utlizing multi-core processors!!!!  Nothing like C3D chugging away and only 1/4 of my processor being used.
    New features are great, but a stable 64-bit multi-core version would be a no brainer to upgrade to, even with no new features.
    Keith Yheulon
    Aviation Design Manager
    RW Armstrong
    BHFH
    Re: Multi-Core Utilization!
    02-24-2012 01:30 AM in reply to: kyheulon
    +100 But I'm doubtful it will ever happen though. Civil 3d feels like a bunch of semi related tools haphazardly thrown together but never quite acts as a cohesive unit .
    **Master
    AllenJessup
    02-24-2012 07:35 AM in reply to: BHFH
    Well. In a way you're right AutoCAD + Map 3D =± Map 3D. Many of the Transparent Commands have existed in Map for years. All the coordinate systems are handled through Map [for the most part]. There are still areas where they don't quite work harmoniously.
    Allen
    BHFH
    02-25-2012 01:30 AM in reply to: AllenJessup
    Well I was talking more about the stormwater tools, having to import and export to SSA and/or Storm Sewers is the biggest "WTF are they thinking" for me. Why can't we set all the parameters for catchments/pits/pipes/storms within Civil 3D and run the analysis engine externally? River analysis is very similar to what I was thinking, HECRAS engine is external, but we can set everything and visualise inside Civil 3D environment.
    Back to the original discussion, I have a feeling mulitthreading is difficult because of the interdependency of civil objects. Surface can't be generated until corridor/grading are finished. Long/cross sections needs to be calculated after both surface and corridor are finished. I'm sure they can think of something as I only code for a hobby afterall!
    02-25-2012 12:54 PM in reply to: BHFH
    I'm sure it's not easy, but other software applications are doing it.  If you look at the gaming industry, they build games to use every available resource in the computer.  Even using available memory or processing in sound cards or video cards.  I'm not expecting anything like that, but Autodesk needs to do what it has to do to start using multiple cores.
