snip>On another topic, I notice that quite a few people are asking for
volumes computed directly from the corridor model, rather than creating
layers etc etc. Is this item worth pursuing?
As long as it had a Dynamic nature - I would assume that to be a
pre-requisite for anything being considered for inclusion into C3D.
And please pardon my "butting-in".
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
AMD Athlon 64 3200+ 2.2GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce FX 5200 128MB
WD 36GB Raptor
wrote in message news:5129705@discussion.autodesk.com...
James,
I am not sure that there is any necessity to automatically create the code.
It is very easy to take a standard template (created in any number of ways)
and set up a program so that it knows about widenings, super etc etc. You
can even make it so that you can add/subtract bits and pieces (e.g. for
parking or buses).
This can all take place as a "smart" subassembly, which would take the
place of most of the roadway, sidewalk and kerb assemblies currently in
civil3d.
The bit that is hardest to do is to build some "logic" into the pavement
layers and the subgrade. While ever you just have layers that have the same
horizontal extents of the surface sections there is no problem. If you want
layers that are "L" shaped or inverted "U" or sideways "U" then it is very
difficult to code them simply and keep them in sync with the surface points.
The easiest way is to draw it, but you still have to do something special if
the subgrade layers do not keep their relativity to the surface when you
have superelevation or transitions.
I have "played" around with this a little. I used the existing Advanced
Road Design template and subgrade system to generate offsets and levels in
a file. I then read in this file and recreated the road sections in the
civil3d corridor (taking into account transitions, super, as well as a
complex layering for the subgrade).
The real question is is there sufficient demand for a "smart" assembly to
make it easier for the advanced user, when you can achieve exactly the same
thing by piecing together a number of subassemblies and using the product
out of the box.
Let me know if you think that this is worth pursuing. It is not hard to do
and if it would (a) make it easier to use civil 3d and (b) save designers
time and (c) have enough people buy it to justify the development time, I
would be happy to develop the code.
On another topic, I notice that quite a few people are asking for volumes
computed directly from the corridor model, rather than creating layers etc
Peter Bloomfield
