In other programs, MDT, ISPOL, etc.. if we can createpolylines indicate a range of points.
We indicate the number begin point and end point numberand creates a polyline that passes through these points.
This is useful if you have a drawing that someone else has done and we have no data base figure prefixes.
There may be a routine, which in addition to this, ask if we get a polyline, a survey figure or feature line.
Take a look at Transparent Commands in the help menu. the 'PN command, when used after starting the 3d polyline command, will accomplish what you are looking for.
Yes, it´s true.
I have write the number points in the comand line separated by comma.
Thank you.
You can also use a "-" for a sequence. For example "1-1000" will connect points from 1 to 1000. If there are missing points it will just skip them without causing an error.
Peter Funk
Autodesk, Inc.
