AutoCAD Civil 3D Wishes (Read Only)
Dimension Text
2 REPLIES 2
brad_in_omaha
898 Views, 2 Replies
Dimension Text
I think this would be really easy to make.  I want to be able to add a second line of Dimension text. See Attached example of what I want.
In the past I have always added text under the dimension and rotated it to match, but if you move the dim, the text dosn't go with it.
2 REPLIES 2
Jeff_M
in reply to: brad_in_omaha
Override the DimText:
<>\XTYP.
The <> tells it to use the measured distance, the \X tells it to use another line below the dimension line.
Awesome!  Thanks!
