AutoCAD Civil 3D Wishes (Read Only)
Convert a surface to a solid
11 REPLIES 11
Message 1 of 12
BrianHailey
4422 Views, 11 Replies
I have a client that needs to convert a surface into a solid in order to physically model it for use in a wind tunnel. His modeling software uses the .stl format, which AutoCAD can export to but, in order to do this, you first need a solid.
Perhaps we can bypass this step as well and just export a surface directly to a .stl file.
Brian
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
11 REPLIES 11
Message 2 of 12
in reply to: BrianHailey
ROCK ON.
i have tried a billion times to work civil 3d objects into the autocad 3d
world with minimal success
i have found that if you take a tin and explode it, after much horsing
around you can turn it into a solid. but it aint any fun
Dana Breig Probert, E.I.T.
http://www.civil3d.com
Civil 3D 2007 SP3 alongside Civil 3D 2008
AMD Athlon 64 X2 Dual Core 2.01 GHz
2GB RAM, 256 MB ATI FireGL V5200
AUGI CAD Matinee in Philly May 17
http://www.cadmatinee.com/philadelphia/default.asp for more complete agenda
and registration.
wrote in message news:5569354@discussion.autodesk.com...
first need a solid.
to a .stl file.
Brian
Message 3 of 12
Dana:
Quit worrying about those solids. You need to get me set up with using
points after they dropped my Point Groupies in 2008. Another shift from
forward to reverse in my humble opinion.
Bill
"Dana Breig Probert" wrote in message
news:5569505@discussion.autodesk.com...
ROCK ON.
Message 4 of 12
dude, i promise you they are better. they are faster, easier to manipulate
and the surveyors in your office now have one less thing to complain about.
and registration.
"wfb" wrote in message
news:5569557@discussion.autodesk.com...
Dana:
Bill
ROCK ON.
Message 5 of 12
Hi Brian,
I had not run into an STL file before, but Wikipedia shows it's format as
solid name
Multiple instances of
facet normal n1 n2 n3
outer loop
vertex v11 v12 v13
vertex v21 v22 v23
vertex v31 v32 v33
end loop
end facet
then ends with
end solid name
It appears n1 n2 and n3 can be set to 0
so the only needed data is the v values which I expect would be AutoCAD, X,
Y and Z, or Civil 3D Easting, Northing and Elevation values.
This information is really easy to extract from a Civil 3D DTM.
If this information is correct, I'll churn something out tonight with a
dtm2stl functionality.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
first need a solid.
to a .stl file.
Brian
Message 6 of 12
Many apologies. The triangle data of a surface is not exposed in Civil 3D
R2007. It was in Land Desktop and I had assumed it would be in Civil 3D.
It is still possible to program to write the SLT, but it would require the
user to make a copy of the surface - display it as 3D faces - explode the
surface back to 3D faces and then write the SLT file from the 3D faces.
It also appears there is no real interest in a program as no-one has
bothered to confirm my information about SLT files.
Laurie Comerford
CADApps
www.cadapps.com.au
"Laurie Comerford" wrote in message
news:5569853@discussion.autodesk.com...
Hi Brian,
solid name
outer loop
vertex v11 v12 v13
vertex v21 v22 v23
vertex v31 v32 v33
end loop
end facet
then ends with
end solid name
Laurie Comerford
CADApps
www.cadapps.com.au
first need a solid.
to a .stl file.
Brian
Message 7 of 12
mpeterson79
While STL is ultimately the solution that works well, we try to maintain our drawings as clean & uncluttered as possible. Having to duplicate & explode a surface not only increases drawing size significantly, but creates unecessary drawing entities. Also, having to run LISP routines or multi-stepped functions only increases the chance for user error. As Brian stated, not only is the LISP routine processor intensive, but it's not also the quickest tool in the world.
With the advent of Civil3D 2008, we now have the ability to export a surface as a DEM. This functionality was not available in 2007 (to my knowledge). By utilizing the DEM export ability, combined with some secondary program processing, we are able to quickly & easily generate STL files.
Until we have an STL export function, this seems to be the quickest & cleanest way to achieve and STL file from a surface. The DEM export was definitely a step in the right direction from Autodesk, for our needs. We're getting closer!
Message 8 of 12
Once the STL file is written, there is no reason to keep the data in the
drawing.
A system could easily be made with a menu call to copy the surface, set the
style of the copy, explode it and then run the program to write the STL file
and lastly delete the 3D faces, so that the drawing ended up unchanged.
There is no reason to expect the code would be run slowly whether done with
lisp or VBA or anything else. If done in this way it would almost certainly
be faster from start to finish than any other process which involved the
user exporting a file and then finding that file again with an external
program.
The only user input needed would be to start the program, select the
surface, browse to the required output directory and type the output file
name
If the Surface name was used as the Output file name and the drawing
directory used as the output directory then user input could be reduced
again.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5589151@discussion.autodesk.com...
getting closer!
Message 9 of 12
Efren
I have created a VBA program to extrude the 3D face, vertically to a specified datum. It uses Civil 3D surface.
Performance depends on data-density.
Tell me if you're interested...
Efren
Message 10 of 12
Hi Efren,
I found a lisp routine that basically does the same thing. If you want to
post it here, I'm sure someone will utilize it. The lisp routine I
referenced can be found here:
http://discussion.autodesk.com/thread.jspa?messageID=5305011. I wrote about
this in my blog as well:
http://cadcafe.blogspot.com/2007/04/you-want-solid-from-your-surface.html.
Brian
http://www.ctcivil.com
wrote in message news:5591096@discussion.autodesk.com...
Efren
Message 11 of 12
mpeterson79
I beg to differ as far as not needing to retain data in the drawing after the STL is written. What happens when a grading change occurs, or the surface is altered due to design constraints? Rebuild everything all over again?
If the Civil3D surface remains unaltered in the drawing, we then have the ability to manipulate it further as the design progresses. If by creating the STL, we destroy the surface, progress has been halted.
As far as the speed at which any code might work, I'm curious to test drive the F2S lisp routine (which, unfortunately, requires exploding the surface). As soon as I get another 26 hour day, I may just do that. 🙂
Message 12 of 12
Efren
Here's my program attached as .txt as a module file.
This is actually a .bas file, so you need to rename to .bas
Free to use, copy modify, distribute as long as Author's Name on the Headers is Retained.
You can import it from your VBA modules
Note: 3D Faces assumed to heve been generated by LDD or Civil 3D (by exploding TIN surface object in C3D)
Instructions:
When loaded as vba,
command prompt: -vbarun FacesExtrudeToElevation
Select 3D faces.
After extrusion of 3d Faces to 3D Solids:
Command prompt: UNION
select 3D objects to turn objects into One solid 3D object.
Cheers,
Efren Abella
