• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D Wishes
    *Don Reichle
    Re: AEC Line Objects
    04-07-2006 03:59 PM in reply to: *Andy Urban
    Andy, maybe you missed this portion of my post;
    snip>So that's what leads me to stay in opposition to the Wish - if the
    result
    would be along the lines of LDT's Special Lines at the bottom of the
    Lines/Curves menu.
    end of snip>
    Please notice my "if" in that sentence. Which was followed by my reason why;
    snip>They are indeed useless, unless of course one enjoys having to
    edit(ing - sp?) them
    after further data returns from the field necessitating a change.
    end of snip>
    I would much rather have far more "control" by using a Linetype, versus a
    combination of (numerous) Lines and (numerous) Text entities.
    But we can differ to our heart's content over this matter. It sounds to me
    that each of us has decided which method suits our style.
    I'm really not looking for another convert - whatever floats your boat, to
    coin a popular phrase.
    HTH
    Don Reichle
    "The only thing worse
    than training your staff,
    and having them leave is -
    not training your staff,
    and having them stay."
    Courtesy Graphics Solution Providers
    LDT-2K4
    AMD Athlon 64 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    Nvidia GeForce FX 5200 128MB
    WD 36GB Raptor
    "Audie Osgood" wrote in message
    news:5131061@discussion.autodesk.com...
    I'm confused! If you have text conflicts, and we all do, and there is
    another/easier way to correct those conflicts, why would you be opposed?
    Isn't that like saying, "I don't use the tangent-tangent-radius option to
    draw a circle so I don't want anyone to have the option"?
    I'm very much in favor of the request. I think one of the hardest/most time
    consuming things about completing a set of plans is making it truely
    readable and eliminating ALL the text/linework conflicts. How could anyone
    not be in favor of a tool that would simplify this process?
    Additionally, if the text truely mimics the contour labels, the text would
    be able to rescale and reorient to the current viewport. No more having to
    label the water line twice so it can read properly in two different plan
    views.
    I'll admit I am just getting started on C3D this week (finally!!), but
    unless there's something out there I haven't heard about this seems like a
    great idea!
    Audie
    "Don Reichle" wrote in message
    news:5130052@discussion.autodesk.com...
    I guess I'm of the opinion that I've seen conflicts of this nature in the
    "few" range in my experience. I've dealt with them exactly in the manner you
    described. Or just trimmed them as needed to avoid the conflicts, keeping
    them in their Linetype Generation ON state.
    I would consider this "issue" just a part of putting together a set of plans
    in the least amount of time. My experience is that the "linetypes"
    accomplish that end.
    So that's what leads me to stay in opposition to the Wish - if the result
    Lines/Curves menu.
    They are indeed useless, unless of course one enjoys having to editing them
    Sorry.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    Nvidia GeForce4 MX 4000 128MB
    "Allen Jessup" wrote in message
    news:5129995@discussion.autodesk.com...
    Don,
    I think what he was talking about is that if you make a linetype with Text.
    If the text is blocking something on the plan that needs to be seen it is
    difficult to make that happen. You can take some time with wipeouts and
    draworder. But that has its own problems.
    What I usually do it to make the line into a polyline. Then turn the
    linetypegeneration for that PLine off. Then insert a vertex close to the
    text I want to move. Then grip the vertex and move it along the PLine until
    it looks like it will be clear. Finally I snap to a nearest point on the
    PLine.
    One problem with that is that it will move all the text along the line and
    might cause other conflicts. Then more vertices would have to be inserted.
    So basically I'm in favor of the Wish.
    Allen
    wrote in message news:5129034@discussion.autodesk.com...
    OK I won't mention them.
    As long as you use a LTSCALE of 1, those items will stay the way they need
    to be.
    What happened to turn you against those items use?
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    MB
    Please use plain text.
    *Don Reichle
    04-07-2006 04:01 PM in reply to: *Andy Urban
    Sorry - Audie "should" have been the name I used.
    Not Andy. :-(
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    1GB RAM
    WD 36GB Raptor
    news:5136570@discussion.autodesk.com...
    result
    Lines/Curves menu.
    end of snip>
    end of snip>
    HTH
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    1GB RAM
    WD 36GB Raptor
    views.
    great idea!
    Audie
    Lines/Curves menu.
    Sorry.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    Don,
    PLine.
    Allen
    to be.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    MB
    *Allen Jessup
    04-10-2006 05:26 AM in reply to: *Andy Urban
    Hi Don,
    If I could figure out how to make text into an anchored object we might get
    somewhere with the commands below. Might be something available in 2007. It
    might also work with a dynamic block but I haven't had time to try yet.
    ObjectAnchor - to anchor an AEC object to another AEC object.
    CurveAnchor - to anchor objects to the base curve of other objects.
    LeaderAnchor - to anchor nodes on a layout curve with a leader.
    NodeAnchor - to anchor nodes on a layout curve or grids
    CellAnchor - to attach objects to positions on a 2D layout grid or 3D volume
    grid.
    VolumeAnchor - to anchor objects to volumes on 3D grids.
    LayoutCurveAdd-to space nodes along an object. Creates the nodes to use with
    Node Anchor.
    Allen
    news:5136557@discussion.autodesk.com...
    Not Andy. :-(
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    1GB RAM
    WD 36GB Raptor
    result
    Lines/Curves menu.
    end of snip>
    end of snip>
    HTH
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    1GB RAM
    WD 36GB Raptor
    views.
    great idea!
    Audie
    Lines/Curves menu.
    Sorry.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    Don,
    PLine.
    Allen
    to be.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    MB
    *Peter Funk - Autodesk, Inc
    04-10-2006 05:43 AM in reply to: *Andy Urban
    Allan,
    1. Make a block with your text, and a wipeout.
    2. Make a Multiview block with using your block as the the view block
    3. Anchor the Multiview block to the line using the Node and or Curve
    anchors. The Node anchor will give you even spacing, the Curve anchor will
    allow you to attach additional labels at selected locations.
    After the anchor, the text will move with the curve.
    In 2007, you can also do this with the label, but you won't have the array
    layout like the Node anchor will give you.
    Cheers,
    Peter Funk
    *Allen Jessup
    04-10-2006 06:55 AM in reply to: *Andy Urban
    Thanks Peter. I came to believe that the Multiview block was the key. But a
    pushed ahead project schedule has been keeping me busy. Just waiting for the
    latest redline now. Need to go to the printer before noon!
    Allen
    ; "Inc" wrote in message
    news:5137336@discussion.autodesk.com...
    Allan,
    Cheers,
    Peter Funk
    *Audie Osgood
    04-11-2006 05:21 AM in reply to: *Andy Urban
    Don,
    I did miss the "if", my appologies. I'm not a fan of the special lines
    either and rarely use them. I wouldn't miss them a bit if they wern't
    there.
    Audie
    P. S. - And don't worry about the mane thing. With a name like mine few
    people get it rightthe first time. If I let that bother me my head would
    have exploded a long time ago.
    result
    Lines/Curves menu.
    end of snip>
    end of snip>
    HTH
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    1GB RAM
    WD 36GB Raptor
    views.
    great idea!
    Audie
    Lines/Curves menu.
    Sorry.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    Don,
    PLine.
    Allen
    to be.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    MB
    *Don Reichle
    04-11-2006 07:47 AM in reply to: *Andy Urban
    There was a quite famous WWII war hero with that name - Audie Murphy.
    You may in fact be named after him.
    If so you're in good company. :-)
    I'm glad we're all squared away now and can get on with more important
    issues - like C3D's future applications.
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    1GB RAM
    WD 36GB Raptor
    news:5138632@discussion.autodesk.com...
    Don,
    there.
    Audie
    result
    Lines/Curves menu.
    end of snip>
    end of snip>
    HTH
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    1GB RAM
    WD 36GB Raptor
    views.
    great idea!
    Audie
    Lines/Curves menu.
    Sorry.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    Don,
    PLine.
    Allen
    to be.
    Don Reichle
    C3D/LDT/CD/SVY-2K6
    AMD XP 3200+ 2.2GHz
    XPPro 32bit SP2
    1GB RAM
    MB
    Distinguished Contributor
    04-21-2006 12:37 PM in reply to: *Andy Urban
    I have never used "anchor", but when I try it, it says that the line must be an "Anchored Entity". I think I am missing a step here. Can you expand on item 3? Are you talking about the "anchor" command or are you referring to anchor as used when talking about label styles in Civil 3D?
    Josh Nelson
    *Allen Jessup
    04-24-2006 06:54 AM in reply to: *Andy Urban
    Try
    style="FONT-SIZE: 11pt; COLOR: #555544; FONT-FAMILY: Tahoma; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">
    face="Times New Roman">LayoutCurveAdd.
    This will add nodes to any object. Not just curves despite
    its name.
    color=#000000>
    face="Times New Roman" color=#000000 size=3>Allen
    color=#000000>
    I
    Josh
    Nelson
