AutoCAD Civil 3D Wishes (Read Only)
2D Drafting only Mode
5 REPLIES 5
chrisd
1012 Views, 5 Replies
I would like the option to work with in 2D using 3D files without the requirement to flatten.
I see it working something like this. When Osnap is turned on AutoCAD would give me the option to ignore Z values. This means all lines would be drawn at a specified Z value (more often zero) and I would not have to use the flatten command in order to fillet etc.
Additionally I would also like it when the 2D drafting only mode is set to on, AutoCAD would to ask me what elevation I want to work too (for example Z default 0 or 100 etc)
I find that I do spend quite a bit of time flattening bits and pieces when working on 3D files, when all I want is for the two (2D & 3D) to tie in together a bit easier. I think this would be a very useful tool for cadies and engineers alike.
Cheers,
5 REPLIES 5
in reply to: chrisd
Just make a button with the "osnapz" command.
Bill
wrote in message
news:6230409@discussion.autodesk.com...
Cheers,
in reply to: chrisd
Hi chris,
Why not use the existing tools to do this.
Look under the Drafting tab in the Options form for OSNAP Settings.
Laurie Comerford
> Cheers,
chrisd
in reply to: chrisd
I may be being a little bit blind with this. But I am not sure what or where or how to use the 'existing command'. Please can you be a bit more descriptive in how I activating it so I can find it and so I know you understand what functionality I am after.
Any help appreciated.
Thanks.
JeffPaulsen
in reply to: chrisd
I think this was posted above but to clarify:
Either use the OSNAPZ variable (more info in help) or in Options on the Drafting tab check the box near "Replace Z value with current elevation". They both do the same thing.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
chrisd
in reply to: chrisd
I misunderstood first time. Have it now and its sorted. It is one of those ones that snuck past me somehow. This will be very useful in our office.
