I have some question about calculation peak flow in junction and after junction
The result that I got is deferent, compared with manual calculation using excel
It's seems no problem with peak flow before junction (same as manual calculation)
Example :
Junction 1 recieved flow from link-1 = 5.114 cms and link-2 = 2.517 cms , then junction 1 drain it to link-4 = 7.266 cms (using SSA)
when using manual (excel) : link-1 = 5.136 cms , link-2 = 2.585 cms , and link-4 = 9.037 cms
Note : TOC are almost same
Please tell me computation concept rational method using SSA
Remove ".txt" to open the attachment
Krishna
Please tell me computation concept rational method using SSA...
A dynamic flow routing model like SSA does not use a system TOC and sum of the CA's as is required to implement the Rational Method across multiple basins.
