• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Active Member
    pebo7483
    calc stormwater from a city but im stucked after putting dwg files together
    69 Views, 0 Replies
    11-16-2011 11:19 AM
    Hi
    i have a really hard time knowing what to do next. My goal is to create a drawing over a small city and the surrondning area so i can calculate the the total stormwater runoff. What i have is DWG-files with different parts of the final drawing. Example 1 file with roads, 1 with houses, 1 with contour map, 1 with streams  and so on. I have oppened 1 dwg file and then attached the rest of the files with xref. They seem to fit well together so the scaling seems to be fine.
    No i dont no what to do next, i have read all the guides and there is so much you can do but i dont no what is necessary for me i feel lost in all the information.
    Does the program now that houses is houses and streams are strems..? Or do i need to change something in the files before i attached them or can i do it now. All the attached files seems to be in the background and impossible to do something with.
    In the end i want them all to work together, is it wrong to attach them? should i use the overlay button instead?
    very thankfull for answers
    Please use plain text.
