• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Member
    big difference in External Outflow Volume for a same drainage area
    124 Views, 2 Replies
    02-05-2013 07:52 AM
    I set up model for two options for a same drainage area of 38.8 acres.
    Option 1: Gutter flow upstream and piping flow downstream
    ************************** Volume Volume
    Flow Routing Continuity acre-ft Mgallons
    External Inflow .......... 0.000       0.000
    External Outflow ......... 7.733     2.520
    Initial Stored Volume .... 0.000    0.000
    Final Stored Volume ...... 1.284   0.419
    Continuity Error (%) ..... 0.133
    Option 2: Piping flow for the entire area
    External Outflow ......... 14.791 4.820
    Final Stored Volume ...... 0.127 0.041
    Continuity Error (%) ..... 0.008
    My problem is: Why is the difference of external outflow volume so significant, 7.733 and 14.791? Shouldn't the two values be close, if not exactly the same? Did I set up something wrong in Option 1 which includes gutter flow? Pleseae see the attachments of two options for reference. Thanks a lot.
    Please use plain text.
    New Member
    Re: big difference in External Outflow Volume for a same drainage area
    02-07-2013 06:24 AM in reply to: NoWandering
    Option 1 allows flows to travel along the curb and gutter system (which possibly has different properties from the pipe network and in some case increases TOC) prior to it entering the pipe network below. Thus, longer TOC for the time span would reduce outflow volume. Option 2 allows all flows to enter directly into the system without having to travel through a curb and gutter system first. This results in a single TOC which would be based on the parameters of your pipe network. If the two time spans are identical in both options it is possible that option 1 show less volume than option 2.
    Member
    02-07-2013 02:35 PM in reply to: logate
    I can understand the Peak Flow would be much lower for gutter flow because of TOC. But for the same storm event in a same area, the outflow voulme shouldn't be the same?
