• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    kdave
    Unstable Weirs- Please Help!
    160 Views, 4 Replies
    01-05-2012 06:30 AM
    I have developed a model for a project that I am working on. It is a small but complicated model. I have 3 structures with 2 chambers and have weirs and orifices between the chambers. when I ran the model for 100 year storm and look at the animation, weirs go crazy  with zillion peaks. I am not sure why weirs are so unstable. Can anyone please suggest any solution? I have attached the model here.
    KD
    Please use plain text.
    Re: Unstable Weirs- Please Help!
    01-10-2012 12:25 PM in reply to: kdave
    You could try to increase your time step. Just don't go crazy with it or you could miss your true peak if the time step is too large.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    Employee
    Matt.Anderson
    01-29-2012 08:13 AM in reply to: kdave
    The best advice is to reduce your time step. When you use a large time step, the volume into the pond pushes the pond highwater level up, which corresponds to a discharge that allows more water to leave than the prior time step. Be sure your pond has sufficient stage information as it increments near the weir level.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    kdave
    01-30-2012 05:38 AM in reply to: Matt.Anderson
    Matt, Do you mean reducing the routing time under "Analysis Options"? Currently I have it set at 30 sec (default value).
    Employee
    Matt.Anderson
    01-30-2012 06:47 AM in reply to: kdave
    Yes, reduce the hydraulic routing time step in Analysis options.
    Business Consultant
    Global Services
    Autodesk, Inc.
