• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D - Stormwater
    UK IDF files
    281 Views, 7 Replies
    06-08-2009 06:09 AM
    Is anyone using Hydraflow Storm Sewers in the UK?
    I am having trouble finding any IDF files for UK storms. Does anyone know where I can find them?
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: UK IDF files
    06-08-2009 06:19 AM in reply to: stewartg
    Storm Sewers comes with a few sample IDF files but you will most likely have to create your own. Here in the Denver area, the IDF curves change depending on what part of town you are in. Take the rainfall data you have for the location you are at and create the IDF curves within Storm Sewers. If you do get lucky, you might find someone in your area that's already put some together.
    Brian Hailey
    http://www.cad-1.com
    http://www.AtYourDeskTraining.com
    Distinguished Contributor
    Re: UK IDF files
    07-07-2011 03:13 AM in reply to: BrianHailey
    I'm resurrecting this thread, as we want to start using Hydraflow within Civil 3D and bin the hideous and expensive WinDes that everybody is forced to use.
    So, are there any UK curves/templates/IDF files available anywhere?
    Kevin
    Employee
    Matt.Anderson
    Re: UK IDF files
    07-07-2011 06:10 AM in reply to: ksorsby
    Kevin -
    The Autodesk Storm and Sanitary Analysis has some UK functionlity built in.  IDF Curves for Hydraflow would need to be built with the local records.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    Re: UK IDF files
    07-07-2011 09:24 AM in reply to: Matt.Anderson
    Thanks Matthew,
    In that case does anybody know of a way to export the localised rainfall data from Windes? It won't create .idf files AFAIK.
    I'm assuming somebody here will be UK based and therefore will more-or-less be tied to using WinDes themselves...
    Cheers,
    Kevin
    Active Member
    Re: UK IDF files
    01-30-2013 07:32 AM in reply to: stewartg
    Kevin,
    Did you ever get anywhere with the UK IDF data?
    Re: UK IDF files
    01-30-2013 07:48 AM in reply to: arfrwi2
    In short, no. That said, we have a new hydrologist so he might have some new ideas. I'll ambush him later and post.
    Kevin
    Active Member
    Re: UK IDF files
    01-30-2013 08:23 AM in reply to: stewartg
    Kevin,
    Thanks for that. I assume you are UK based. I have used Windes for about 25 years and although its a good package I'm now looking at alternatives especially as you suggested the costs are high and BIM is becoming more relevant.
    I'm currently trying to run both systems but am having trouble using SSA to do storage assessments as it doesn't run on UK Mod Rat. I'm not that familiar with the other rain fall generators or inputting hydrographs or creating rain fall files, hence to post!!
    Would be nice to get the views of other UK users like yourself who may be looking to use SSA for UK projects.
    Steve
