• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Member
    Total inflow/Total Outflow
    209 Views, 5 Replies
    08-22-2012 02:14 PM
    Would anyone have any idea why my model shows an event mean storage of 20396 cf when I dont have any storage nodes? How is the model storing that amount of water? I'm thinking this is why my total inflow doesnt match my total outflows?
    Please use plain text.
    Valued Mentor
    fcernst
    Re: Total inflow/Total Outflow
    12-03-2012 06:30 AM in reply to: ryannn
    SWMM computes storage in all of the links and nodes, not just storage nodes.
    SSA says it uses the SWMM engine, but they don't say what version, or what modifications, if any, they have done to it.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Employee
    Matt.Anderson
    12-03-2012 07:25 AM in reply to: fcernst
    Ryan -
    Sounds like your model might not be completely draining during the event duration.
    Fred -
    EPA SWMM hydraulic calculation engine for SSA 2013 should be 5.0.21 or 22.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Valued Mentor
    fcernst
    12-03-2012 08:30 AM in reply to: Matt.Anderson
    Thanks Matt.
    Just curious, how can you not be sure of the version in 2013 now? It says here you're an employee, is that right?
    Ernst Engineering
    Fred Ernst, PE
    Employee
    Matt.Anderson
    12-03-2012 08:36 AM in reply to: fcernst
    Fred -
    Yes, I am an employee.
    The difference between the EPA SWMM 21 & 22 engines are a couple of "engine update" changes that I am not 100% certain are covered.
    Business Consultant
    Global Services
    Valued Mentor
    fcernst
    12-03-2012 08:50 AM in reply to: Matt.Anderson
    Sorry, but I don't understand your logic there... it should be just clear...What SWMM version?
    It should also be listed in the About under the software Help, like most software list their versions and updates. then in your methodology section, talk about any differences between the SSA engine and the SWMM engine, any modifications.
    Example: "We are using SWMM version 5.0.022, however we are not using the LID capabilties", etc...
    Ernst Engineering
    Fred Ernst, PE
