I have a simple model using 10 years of hourly rainfall data. When I generate a time series plot an box pops up stating SSA has encountered an error. I can click on the continue button and the plot will generate. This box pops up each time I add or delete a (subcatchment, node, link) on the view. I have attached a screen shot of the error box. I also have a debug.txt file that I can send to Tech Support. I am using the May 2011 build. Thank you.
Len Linton
Windows 7 64 bit. 8 GB Ram
Hi Len,
I have the same problem and I have also sent the debug file to tech support without any response.
-Scott
Scott,
Can you provide a case number so I can find out what happend here?
Hi Justin, Is there a solution to this error? I am getting it too. And the dialog will not allow me to emil the bug report. When I continue it plots the TS but the summary table is blank
Joe Bouza
I get the same error. What is the reason for this error? What is the solution? Initially I submitted bug reports but never got a response so I ignored the error. But yes in that case we don't get a table below the time series plot. What is the solution? Please help..!
If you do not get a table below the time series plot, right-mouse click within the time series plot window > Show Summary Information.
