The subbasin hydrology report is great, but for some reason I cannot edit the content, unlike the other reports.
Specifically, when using the rational method to size storm drain pipes, it doesn't make sense to list total rainfall or total runoff since it is a peak design flow method and it could be confusing for reveiwers. Since I cannot add intensity to the "Subbasin Summary" (which is weird anyway, seems like a fundamental part of the Rational Equation that should be listed here as default), this is the only part of the report where I can display or verify what value was used for intenstiy when calculating the peak runoff rate.
Has anyone found something I am missing, or is there a work-around for this (short of just deleting it in an excel report)?
Any help is appreciated, thank you.
