• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Member
    Storm Sewers zero flow warning
    261 Views, 2 Replies
    07-16-2012 10:06 AM
    The error is where I run the system it says that certain lines do not have flow, they don’t have direct flow in the upstream manhole because they are manholes and only for turning the system. I've tried on other, older files that I know have been run and I'm running into the same issue. I’ve also tried on other computers and having the same problem. It happens with any file I open that has a manhole with no direct flow into it. How to I let storm sewers know that certain manholes don't have direct incoming flow and ignore them. If I click okay or the X button, it shuts down storm sewers and I have to restart the program.
    Thanks in advance for the help!
    btw I'm running 2012 version, I've tried with 2013 but I get the same warning, but the program does not shut down.
    I've attached the .stm file as a .txt, change the extension back to .stm and it should work.
    Please use plain text.
    Employee
    Matt.Anderson
    Re: Storm Sewers zero flow warning
    07-17-2012 08:12 AM in reply to: PaulsonM
    There are two issues.
    1. The warning is a warning only.
    2. It appears that it is crashing after pressing OK.
    Please open a Subscription support request.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    Active Contributor
    08-02-2012 10:00 AM in reply to: PaulsonM
    And? Any solutions?
