AutoCAD Civil 3D - Stormwater
New Member
TimOConnor2000
Message 1 of 3 (258 Views)
Storm Sewer V9.0 vs V10.0
258 Views, 2 Replies
01-04-2013 01:47 PM
I am running a *.stm file in C3D 2012 and then in C3D 2013 and I am getting different results.  Specifically, the some of the HGL have changed by up to 0.9 ft, the friction slope in the newer version is typically 0.000, and there are differences in some of the EGL, velocity head and minor losses.  The design codes appear to be the same in both.   I have tried a couple other *.stm files and am getting different results w/ them also.  Is there a setting or something that I am missing?
Tim
Employee
Matt.Anderson
Message 2 of 3 (257 Views)
Re: Storm Sewer V9.0 vs V10.0
01-04-2013 02:08 PM in reply to: TimOConnor2000
Please verify that which versions of 2012 and 2013 that you are running.  There were some changes in 2012 SP2 and 2013 SP1 that might cause the disjointed calculations.
Can you open a support case?
Matthew Anderson, PE
Product Manager
New Member
TimOConnor2000
Message 3 of 3 (241 Views)
01-07-2013 06:06 AM in reply to: Matt.Anderson
We are using 2012 SP2 and 2013 SP1.  We will open a support case.
Thanks.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
