• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    New Member
    Storm Sewer V9.0 vs V10.0
    150 Views, 2 Replies
    01-04-2013 01:47 PM
    I am running a *.stm file in C3D 2012 and then in C3D 2013 and I am getting different results.  Specifically, the some of the HGL have changed by up to 0.9 ft, the friction slope in the newer version is typically 0.000, and there are differences in some of the EGL, velocity head and minor losses.  The design codes appear to be the same in both.   I have tried a couple other *.stm files and am getting different results w/ them also.  Is there a setting or something that I am missing?
    Tim
    Please use plain text.
    Employee
    Matt.Anderson
    Re: Storm Sewer V9.0 vs V10.0
    01-04-2013 02:08 PM in reply to: TimOConnor2000
    Please verify that which versions of 2012 and 2013 that you are running.  There were some changes in 2012 SP2 and 2013 SP1 that might cause the disjointed calculations.
    Can you open a support case?
    Matthew Anderson, PE
    Business Consultant
    Global Services
    New Member
    01-07-2013 06:06 AM in reply to: Matt.Anderson
    We are using 2012 SP2 and 2013 SP1.  We will open a support case.
    Thanks.
