AutoCAD Civil 3D - Stormwater
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Simple Stormwater Routing in SSA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm trying to make a direct comparrison of a SSA Routing (Basin Runoff to Pond with outfall to a weir / orifice tied to a junction followed by a pipe and then the outfall. For some reason the peak flows generated discharging into the pond are excessive, while the flows generated from the basin (~3 acres in area) ruonoff are very reasonable. Perhaps someone may be able to offer some feedback.
Again the scenario being modeled is very basic / straightforward.
Thanks in advance for anyones feedback.
Carl
Re: Simple Stormwater Routing in SSA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There are a few things I noticed in taking a quick look at your model. You should take a look a the elevations and the storage curve you have set up. Your first entry should be a depth of '0' and increase from there. In the Storage Node dialog box you set invert elevations and in the Storage Curve inputs you have to enter "depths".
It looks like somthing is wrong with the weir link. The water surface elevation in your basin has not reached the crest elevation the the weir but it is flowing 45cfs. Also, you are not getting any rating curves forthe weir.
I would either try recreating the weir link or starting the model over. It is a fairly simple model with few inputs.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Carl -
Here are a couple of tips:
1.) Invert of the pond is currently at zero. The weir is at elevation 12. This is why the rating curve does not calculate. Edit the Pond Invert to 9.5.
2.) Review the Analysis options and change the Routing time step from 30 seconds to 1 sec. Change the Reporting time from 5 minutes to 1 minute.
3.) Change the Lenghtening time step to 15 seconds.
The model will run and be stable.
Matthew Anderson, PE
Business Consultant
Global Services
