• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D - Stormwater
    New Member
    Simple Pipe Analysis
    339 Views, 4 Replies
    04-03-2012 11:30 AM
    This may be the dumbest question ever posted, but how do I use Civil 3D to do basic pipe analysis computations? For example, I give it the slope, material, etc. and it spits out the flow velocity, flow depth, slope min, etc.
    All I want for now is a basic tool for sizing pipes without all the bells, loops & whistles. I can learn the fancy pipe networking stuff later.
    Please use plain text.
    Employee
    Charlie.Ogden
    Re: Simple Pipe Analysis
    04-05-2012 02:36 PM in reply to: bblazer95
    Does this mean you want to size pipes without creating pipe networks...? or are you looking for a simple method without too much of the analysis tools?  If the former you could use one of the analysis applications, if the latter you could use expressions in labels to calculate the capacity using the Manning equation.
    bblazer95 wrote:
    ...how do I use Civil 3D to do basic pipe analysis computations? For example, I give it the slope, material, etc. and it spits out the flow velocity, flow depth, slope min, etc.
    You'd need to give it a flow also... what hydrology method do you need to use?  Analysis computations are performed in the included analysis applications.  Hydraflow Storm Sewers will let you size pipes based on the Rational Method.  Storm and Sanitary Analysis will calculate the flow to pipes based on other methods.
    Charlie Ogden, P.E.
    Sr. QA Analyst
    Autodesk, Inc.
    New Member
    04-06-2012 07:15 AM in reply to: bblazer95
    You could use an expression in a pipe label to show max Q and the pipe diameter and slope.
    Check this out, it's in the C3D user documentation.
    http://docs.autodesk.com/CIVIL/2010/ENU/AutoCAD%20Civil%202010%20User%20Documentation/index.html?url...
    04-13-2012 08:16 AM in reply to: bblazer95
    Why not just use the Hydraflows 'Express' tool to determine that? It gives you the simple tools you need to quickly size culverts, channels, inlets and curb spread, and weirs. Then just type in the results to the pipe properties and you can build labels and tables from there. Quick, easy, and you don't need to build a model to do it.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    Valued Contributor
    04-13-2012 04:47 PM in reply to: ccoles
    Well Hydraulics is the part I long for C3D to reach at, where we can use simple pipe anlysis and get some answers! We have the basic toos of anlysis right now with the program. I have spent a good chunk of the day getting the Civil 3D template to 2013 version and I can see some "HYDR" layers. I got to dig a little more on the interface of these good stuff with SSA now. Things are getting intersting now! Hydraulics and Hydrology is not just grading or alignment tools, Autodesk is getting close!
    Civil 3D x64 2013
    Win 7 x64
    Intel Core i7-940XM
    8 GB RAM
    Quadro FX 5000M
