This may be the dumbest question ever posted, but how do I use Civil 3D to do basic pipe analysis computations? For example, I give it the slope, material, etc. and it spits out the flow velocity, flow depth, slope min, etc.
All I want for now is a basic tool for sizing pipes without all the bells, loops & whistles. I can learn the fancy pipe networking stuff later.
bblazer95 wrote:All I want for now is a basic tool for sizing pipes without all the bells, loops & whistles. I can learn the fancy pipe networking stuff later.
Does this mean you want to size pipes without creating pipe networks...? or are you looking for a simple method without too much of the analysis tools? If the former you could use one of the analysis applications, if the latter you could use expressions in labels to calculate the capacity using the Manning equation.
@bblazer95 wrote:
...how do I use Civil 3D to do basic pipe analysis computations? For example, I give it the slope, material, etc. and it spits out the flow velocity, flow depth, slope min, etc.
You'd need to give it a flow also... what hydrology method do you need to use? Analysis computations are performed in the included analysis applications. Hydraflow Storm Sewers will let you size pipes based on the Rational Method. Storm and Sanitary Analysis will calculate the flow to pipes based on other methods.
You could use an expression in a pipe label to show max Q and the pipe diameter and slope.
Check this out, it's in the C3D user documentation.
Why not just use the Hydraflows 'Express' tool to determine that? It gives you the simple tools you need to quickly size culverts, channels, inlets and curb spread, and weirs. Then just type in the results to the pipe properties and you can build labels and tables from there. Quick, easy, and you don't need to build a model to do it.
