Civil 3D Forum
SSA output results don't seem to make sense. Simple Storm water model
13 REPLIES 13
Message 1 of 14
tonykhoury
2319 Views, 13 Replies
I would like some help please, i need to figure what's going with my model. I have a very simple model of concrete pipes and mainholes, with few catch basin areras.
When i run the result and go to plot, two of the pipes in system are modeled as full at time 0. I dont understand why.
Can anyone please look at the  file and check link 28, and link03 and tell me why are they modeled as full, that doesnt make any sense. I am not sure if it is a mistake in my model or a flaw in the software. I spent 2 days and  i still cant figure it out.
Any help is highly appreciated.
I can't attach the file. I will email it to you. I attached an image of the results i am getting.
Thank you in advance.
Tony
13 REPLIES 13
Message 2 of 14
wfberry
in reply to: tonykhoury
Not that I can help, but you will get better responses if you attach the file.  Is there a reason you cannot attach it?  Rename the suffix to ".txt" if that is your problem.
Bill
Message 3 of 14
tonykhoury
in reply to: wfberry
Hi Bill,
i changed the extention of the SSA file to txt, and i attached it.
Thank you
Message 4 of 14
fcernst
Do you mean just in the Profile graphic? The time series plot and table show zero with peaks around the 12th hour.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 5 of 14
tonykhoury
in reply to: fcernst
Please see the attached profile. Link 3 is showing at full capacity, how is that  possible ?
Message 6 of 14
fcernst
Right, the profile graphic looks wrong at startup. Take a look at the time series for this link though.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 7 of 14
tonykhoury
I did look at it, it starting full at time zero which doesnt make any sense.
Message 8 of 14
fcernst
The time series doesn't show depth until 00:54:05 for me. Is that what you get?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 9 of 14
tonykhoury
I get the same results for the table, but i am not sure what's happening with the profile plot.
Message 10 of 14
fcernst
Change your routing method from kinematic to hydrodynamic and see what you think.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 11 of 14
tonykhoury
Hi fcernst,
I tried it with hydrodynamic and it is working fine.
Any ideas why it didn't work with kinematic ? is hydrodynamic as good as kinematic ?
Thank you
Message 12 of 14
fcernst
The kinematic option does not like the multiple conduits attached to Jun-02.
Lowering the Curve Numbers and areas in Basin 0.72 and 0.29, so there is no runoff (0 cfs) generated, still creates the bogus profile.
Altogether deleting links 28 and 30, results in Link-03 looking normal.
Also kinematic wave can only convey flows up to the links design capacity (no pressure flow), and subasin 0.5DA1-IMP is generating runoff in excess of Link-03's capacity.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 13 of 14
tonykhoury
Thank you
Message 14 of 14
tonykhoury
fcernst,
Can you please help me again. I have a problem that i have been trying so hard to solve without luck.
it is a really simple model and i used hydrodynamic like you told me before, but the results dont make any sense. The energy grade line is higher than the hydraulic grade line at the Manhole - which i think it is impossible. Please see the file attached.
Tony,
Rail Community
