AutoCAD Civil 3D - Stormwater
New Member
hansenbk
Message 1 of 1 (124 Views)
SSA Simple Backwater Analysis
124 Views, 0 Replies
08-10-2012 02:53 PM
I'm attempting to run some simple backwater analysis using SSA 2012.
I am trying to simply provide a tailwater elevation at a downstream outlet, add a single peak flow to a serious of catchbasins and determine the HGL at each catchbasin using the flow inputs.
I'm trying not to use any of the hydrolic functions in SSA to compute the flows, only using the hydraulics fuctions and the flows I manually input.
It seems like the Average HGL is providing what I need, however it differs from the Max HGL.  I can't determine why this would be, as I am only looking at one set of flows and not a time series.
If anyone has any experience with something similar to this, I would appreciate any advice.
I've attached the model I created for clarification if that is helpful (renamed as a .dwg)
Thanks!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
