• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Valued Mentor
    fcernst
    SSA - Inlet Rim Elevations and Weir Flow
    163 Views, 4 Replies
    12-08-2012 01:10 PM
    This inlet scematic is tough for Inlet Rim Elevation.
    Do I have all of the following Rim Elevation situations correct?
    Also, does SSA include all four sides of a grate inlet that is not in a curb setting for its perimeter length in its weir flow calculation?
    Fred
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Please use plain text.
    Employee
    Matt.Anderson
    Re: SSA - Inlet Rim Elevations and Weir Flow
    12-10-2012 05:45 AM in reply to: fcernst
    Fred -
    The Inlet Rim Elevation would the elevation at the gutter flow line.  The Combination Image shows a depression, so you've labeled the top of curb opening.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Valued Mentor
    fcernst
    12-10-2012 05:52 AM in reply to: Matt.Anderson
    Thank you for the clarification. Makes more sense.
    It just looked like in that schematic that it might have been pointing to that dashed hidden orthoraphic line that goes to the top of the opening.
    Ernst Engineering
    Fred Ernst, PE
    Active Contributor
    12-18-2012 12:59 PM in reply to: fcernst
    Fred
    In response to your second question... I have asked this before.  Not much help, but you can look at the following thread for some more info:
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Stormwater/SSA-Drop-Inlets/td-p/2754376
    Valued Mentor
    fcernst
    12-18-2012 02:40 PM in reply to: jmiller0621
    Thanks jm. I understand your frustration..
    Yes, responses like  "I think" and "probably.."  are not helpful from the Autodesk Technical Consultant.
    Ernst Engineering
    Fred Ernst, PE
