AutoCAD Civil 3D - Stormwater
Valued Mentor
fcernst
Message 1 of 5 (479 Views)
SSA - Inlet Rim Elevations and Weir Flow
479 Views, 4 Replies
12-08-2012 01:10 PM
This inlet scematic is tough for Inlet Rim Elevation.
Do I have all of the following Rim Elevation situations correct?
Also, does SSA include all four sides of a grate inlet that is not in a curb setting for its perimeter length in its weir flow calculation?
Fred
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Employee
Matt.Anderson
Message 2 of 5 (469 Views)
Re: SSA - Inlet Rim Elevations and Weir Flow
12-10-2012 05:45 AM in reply to: fcernst
Fred -
The Inlet Rim Elevation would the elevation at the gutter flow line.  The Combination Image shows a depression, so you've labeled the top of curb opening.
Matthew Anderson, PE
Valued Mentor
fcernst
Message 3 of 5 (465 Views)
12-10-2012 05:52 AM in reply to: Matt.Anderson
Thank you for the clarification. Makes more sense.
It just looked like in that schematic that it might have been pointing to that dashed hidden orthoraphic line that goes to the top of the opening.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Active Contributor
jmiller0621
Message 4 of 5 (441 Views)
12-18-2012 12:59 PM in reply to: fcernst
Fred
In response to your second question... I have asked this before.  Not much help, but you can look at the following thread for some more info:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Stormwater/SSA-Drop-Inlets/td-p/2754376
Valued Mentor
fcernst
Message 5 of 5 (436 Views)
12-18-2012 02:40 PM in reply to: jmiller0621
Thanks jm. I understand your frustration..
Yes, responses like  "I think" and "probably.."  are not helpful from the Autodesk Technical Consultant.
Fred Ernst, PE
C3D 2015
Ernst Engineering
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
