Previous versions to 2014 worked correctly. I have a drawing with a pipe network in it, export out to SSA and pipe network comes in perfect, but one of my surfaces does not display. Also my corridor displays even though it is frozen in the drawing. I go through the layer manager in SSA and turn all layers on and still no surface, two proposed surfaces display, but not the existing surface. I found the layers to turn off the links in the corridor, but never had this problem with previous versions. All I want is the drawing to show up the way it looks on export from Civil 3D. Anyone else have this happen? Walter
Thank you,
Walter
IDSP Premium 2016
Win 7 Pro x64, 256Gb SSD, 4Tb HDD
16Gb Ram Intel i7-5930K @ 3.50GHz
3-NVIDIA GTX 970 4Gb (12Gb) Triple Monitors
