I currently have both 2012 and 2014 installed on my machine. I am not sure if this is the source of my issue, but I can not get any dwg to load as a background image. When I locate the dwg I want to use as a background and click ok, nothing shows up. Any assitance would be appreicated.
I am sure you have already tried all of the below but wanted to offer a few suggestions in case they may help:
1. does it show up far away? can you find it when you do a zoom extents in SSA?
2. when you import the CAD drawing, under "CAD LAYERS" in the Layer Manager window, are all the layers turned off?
3. I cannot test this one since I do not have multiple versions anymore, but are you saving the dwg to a higher version and tyring to import that into a lower version of SSA?
Hi Tim,
Please re-install SSA 2014 and open a support request if the issue continues.
