• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Active Contributor
    River analysis license
    80 Views, 1 Replies
    12-20-2012 12:55 PM
    Anyone know what the deal is with River analysis?  It says our license will expire at the end of the month, but I can't find where to renew it?
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: River analysis license
    12-26-2012 12:26 PM in reply to: weserphillip
    Have you called your Reseller to see when it might be available?
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/River-analysis-extension/m-p/3741158/highlight/true#M...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
