AutoCAD Civil 3D - Stormwater
Active Contributor
rhschneider
Message 1 of 5 (336 Views)
RIVER ANALYSIS
336 Views, 4 Replies
07-06-2012 01:15 PM
Am working in River Analysis dwg and go to save and get message "One or more objects cannot be saved to the specified format."
What's the deal?
Active Member
wesley
Message 2 of 5 (296 Views)
Re: RIVER ANALYSIS
07-19-2012 06:45 AM in reply to: rhschneider
I've had this happen and never found a good answer. I had to restart my drawing from scratch, I'm sad to say. I suspect it had something to do with sheet set manager, but couldn't verify.
Good luck
Employee
Matt.Anderson
Message 3 of 5 (294 Views)
Re: RIVER ANALYSIS
07-19-2012 07:06 AM in reply to: rhschneider
If you feel that this is related to River Analysis, please submit the feedback to the labs.civil3d.river email address.
Matthew Anderson, PE
Active Contributor
rhschneider
Message 4 of 5 (113 Views)
Re: RIVER ANALYSIS
12-27-2013 01:09 PM in reply to: Matt.Anderson
DECEMBER 2013
This is happening again. Began saving after every command and when I created 1st river section got the message. Very frustrating!!
Employee
Matt.Anderson
Message 5 of 5 (89 Views)
Re: RIVER ANALYSIS
01-02-2014 01:32 PM in reply to: rhschneider
I have seen others during my AU lab get the same error, but I have not been able to reproduce the situation that produces the issue.
I would suggest opening a support request.  In the request, we will likely need to know what other Autodesk software is installed to determine what is causing the conflict and error message.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
