AutoCAD Civil 3D - Stormwater
New Member
JoshBoultbee4604
Message 1 of 1 (132 Views)
RE: Inlet bypass for "combination inlets on grade" and "inlet depression":
132 Views, 0 Replies
09-19-2012 09:37 AM
Modeling the same storm sewer system that has combination inlets on grade with 2" depression will produce different bypass results in each version.
Why? Adding inlet depression to the design in the 2005 version affects bypass results whereas it does not affect bypass in the 2008 version. If the
2008 version is correct, then would it be appropriate to model a depressed combination inlet on grade by leaving the depression value at "zero" but increasing the gutter cross slope to a value that approximates the steep cross slope caused by the depressed inlet?
Any help would be appreciated.
Thanks in advance,
Josh
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
