Civil 3D Forum
Pressurized Pipe Networks
4 REPLIES 4
Hugh_Compton
793 Views, 4 Replies
Can Stormwater calculate pressurized pipe networks in a similar way to Epanet?
4 REPLIES 4
wfberry
in reply to: Hugh_Compton
I do not know what Epanet does exactly but I can tell you Stormwater or SSA does ZILCH for pressure systems.
Bill
Hugh -
SSA has pumps and forcemain components that work like EPA-SWMM.  EPANET is water distribution calculations.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Thank you to both of you for your helpful replies.
Since I need Epanet for pressure systems I will look into using Epa SWMM with the hope that there are similiarities in the programs making them easier to learn.  I intend to return here eventually to report on success / failures of trying the programs.
rwalpole
Hello!
How can I access to the pipe civil 3d catalog?
Rail Community
