• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Member
    Pipe crossing and projection issue in profile view
    252 Views, 3 Replies
    06-07-2012 10:43 AM
    I'm having an issue where the symbols for a pipe are showing at a different inverts for projected and crossing, for the same pipe. I'm sure that doesn't make sense. In other words, it is just a crossing pipe that is displayed in a profile. When I turn on my crossing pipe symbol, all is good and I know where the pipe crosses my alignment. However, I discovered this because I was trying to drag the pipe label to the center of the crossing pipe and it was off. I then discovered that when I turned on the projected pipe lines for the crossing pipe, it is showing up in a different location vertically.
    I verified that the crossing sybmol is at the right invert based on checking the crossing pipe profile. So why would the projected lines not cross through the crossing linework? Makes no sense. The attached screenshot may be of help. The pipe in question is "FM" and is crossing "WL31 (3) and WL31 (1), at point "VB4"
    Please use plain text.
    Re: Pipe crossing and projection issue in profile view
    06-21-2012 08:13 AM in reply to: jharry1234
    To my best knowledge and experience, the 'projection' of line "FM" is actually an attempt by the profile tool to profile the pipe 'FM'. But, the profile tool has a dificult time profiling a pipe that is skewed through or offset from the alignment, and returns unpredictable results. In these cases, I find that the best solution is to use a pipe style override to show the pipe "FM" by a style that uses the pipe crossing only on just that profile. This would eliminate the a pipe 'projection' that the profile tool is displaying incorrectly.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    Member
    06-21-2012 08:19 AM in reply to: ccoles
    Thanks for the response. That was what I figured as well. Just can't figure out why the projected pipe doesn't cross at the "crossing pipe" style location, even if the rest of it is incorrect. It's too bad because you can't use an automated label for the crossing pipe because it puts the text in the wrong spot. For now I have to manually insert profile view labels, which is OK, but not ideal.
    06-21-2012 09:52 AM in reply to: jharry1234
    Just to let you know that normally this type of question would be best answered in the Civil 3D NG.  The Stormwater NG is normally for the software operation of the two stormwater programs forf the Civil 3D product.
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/bd-p/66
    Bill
