AutoCAD Civil 3D - Stormwater
Active Member
telson
Message 1 of 6 (786 Views)
Perforated Pipe and Trench
786 Views, 5 Replies
10-25-2011 10:22 AM
My company uses alot of perforated pvc pipe in a stone trench, as an underdrain in alot of our projects. As the recent graduate from University I have been tasked with learning SSA and how to model some of our more complex designs. I seem to have a handle on most of the software except for how to model this piece of pipe.
I am just wonder what is the best way to model these in SSA, as they are both storage and inlets.
Thank you for your help.
Active Contributor
WalterL
Message 2 of 6 (778 Views)
Re: Perforated Pipe and Trench
10-25-2011 06:35 PM in reply to: telson
You could look at all the pipe as a storage area with multiple horizontal orifices.
Valued Mentor
ccoles
Message 3 of 6 (766 Views)
10-27-2011 12:20 PM in reply to: WalterL
How about the case for an 'Enhanced Water Quality Swale', where the stored water needs to infiltrate through an engineered sand filter to an underdrain connected to the rest of a storm drain system. Because of the prescribed infiltration rate (1.5in/hr) of the sand material (30" deep), there is a substantial delay between the time the first drop hits the swale to the time the first drop reaches the underdrain. I've been at a complete loss to figure out how I can get SSA to model this properly.
Windows 7 64-bit
HP Z600 8 Gig RAM
Civil 3D 2013
kdave
Message 4 of 6 (691 Views)
02-20-2012 01:27 PM in reply to: ccoles
Was this ever resolved? I am in the same situation. I am trying to model stormwater sanfilter that has sand media and a perforated underdrain pipe beneath it. I have no clue how to model it in SSA. Any suggestions Autodesk?
KD
amit1304in
Message 5 of 6 (681 Views)
02-20-2012 07:18 PM in reply to: kdave
Perforated trench can be model as underground pipe storage. That can be define in Storage curves
Active Member
telson
Message 6 of 6 (673 Views)
02-21-2012 04:04 AM in reply to: amit1304in
This is how I ended up using this, just determine the overall storage available and used it as a storage curve.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
