• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Active Member
    telson
    Accepted Solution
    Perforated Pipe and Trench
    390 Views, 5 Replies
    10-25-2011 10:22 AM
    My company uses alot of perforated pvc pipe in a stone trench, as an underdrain in alot of our projects. As the recent graduate from University I have been tasked with learning SSA and how to model some of our more complex designs. I seem to have a handle on most of the software except for how to model this piece of pipe.
    I am just wonder what is the best way to model these in SSA, as they are both storage and inlets.
    Thank you for your help.
    Please use plain text.
    Active Contributor
    Re: Perforated Pipe and Trench
    10-25-2011 06:35 PM in reply to: telson
    You could look at all the pipe as a storage area with multiple horizontal orifices.
    10-27-2011 12:20 PM in reply to: WalterL
    How about the case for an 'Enhanced Water Quality Swale', where the stored water needs to infiltrate through an engineered sand filter to an underdrain connected to the rest of a storm drain system. Because of the prescribed infiltration rate (1.5in/hr) of the sand material (30" deep), there is a substantial delay between the time the first drop hits the swale to the time the first drop reaches the underdrain. I've been at a complete loss to figure out how I can get SSA to model this properly.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    kdave
    02-20-2012 01:27 PM in reply to: ccoles
    Was this ever resolved? I am in the same situation. I am trying to model stormwater sanfilter that has sand media and a perforated underdrain pipe beneath it. I have no clue how to model it in SSA. Any suggestions Autodesk?
    KD
    02-20-2012 07:18 PM in reply to: kdave
    Perforated trench can be model as underground pipe storage. That can be define in Storage curves
    Active Member
    telson
    02-21-2012 04:04 AM in reply to: amit1304in
    This is how I ended up using this, just determine the overall storage available and used it as a storage curve.
