AutoCAD Civil 3D - Stormwater
Active Member
carl
Message 1 of 2 (101 Views)
Orifice model
101 Views, 1 Replies
12-06-2012 09:12 AM
The file attached has an orifice attached to a detention basin leading to an inlet.  The flow through the orifice is .13 but it shows no flow into the inlet.  I do not understand why.  I'm not sure if I'm connecting the orifice correctly.  I've looked at the profile and run the animation and the water rises in the detention basin and it flows out but it does not run through the inlet.  I'm not sure where it goes.
any help would be much appreciated.
Thanks.
Valued Mentor
fcernst
Message 2 of 2 (95 Views)
Re: Orifice model
12-06-2012 11:09 AM in reply to: carl
Yeah, it's going right on into Link-06, but not registering in the Inlet object.
I simply converted the Inlet-03 object to a Junction, and then you can see the flow registering in the Junction. See below:
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
