AutoCAD Civil 3D - Stormwater
Active Member
kahligsm
Message 1 of 4 (327 Views)
Orifice Rating Curve Calculated Incorrectly in SSA
327 Views, 3 Replies
09-14-2012 08:40 AM
I noticed today that the orifice rating curve for orifices is being calculated incorrectly in SSA.  The head is being calculated to the orifice invert instead of to the orifice centerline.  This probably has a minor (or no) effect if tailwater conditions are present, but it is still annoying.
Valued Mentor
fcernst
Message 2 of 4 (288 Views)
Re: Orifice Rating Curve Calculated Incorrectly in SSA
11-28-2012 02:26 PM in reply to: kahligsm
Is it doing it beyond the unsubmerged orifice calculation that uses weir flow until orifice submergence? Let me know.  See below:
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Valued Mentor
fcernst
Message 3 of 4 (266 Views)
12-06-2012 04:45 PM in reply to: kahligsm
I didn't find this to be the case running a quick test on a headwater submerged 1' diameter circular side orifice with g=32.2 ft/s^2 and PI out to 15 digits.
Their diagram in the Help is incorrect (see second image below). H for a headwater submerged orifice should be measured to the centroid of the orifice.
I hope they are using EPA SWMM engine release 5.0.019 or higher, where the Villemonte correction for downstream submergence in partially full orifices was added.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Employee
Matt.Anderson
Message 4 of 4 (246 Views)
12-07-2012 12:25 PM in reply to: kahligsm
The dialog box rating curve incorrectly calculates orifice flow's H.  This rating curve is not used in the hydraulic routing calculations performed by the analysis engine.  I have notified the development team of the issue in the dialog box and in the help file.
The Villemonte correction changes from the EPA SWMM 5.0.19 engine are included in SSA 2012 and 2013.
Matthew Anderson, PE
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
