Hi....I've encountered a similar problem as well in a couple stm files in storm sewers 2010.
I'm not using SSA however. I'm going from Civil 3d, export to storm sewers, open in storm sewers and have numerous outfalls, in locations of curb inlets.
It normally happens at the most upstream curb inlet of the network, or in a location where I have three pipes coming together..... any thoughts on what is causing the outfalls?
thanks.
You need to watch the pipe flow direction in Civil 3d. A structure in Civil 3d is allowed to have multiple pipes that leave it, however, Hydraflow can not handle that situation and it will create multiple outfalls to accommodate the problem.
Hi I am having the same issue, the only difference is that i have inlets connecting to inlets
Watch John Sayre's video titled "Civil 3D and SSA Workflow-Storm water Inlet and Pipe Design workflow". It demonstrated how you can re-connect the bypass link away from each outfall to the next inlet.
