Civil 3D Forum
Multi-stage Riser
7 REPLIES 7
Message 1 of 8
kdave
1348 Views, 7 Replies
Multi-stage Riser
First of all, I want to say that this discussion group has been very helpful. Thanks to Matt who responds quickly and solves the problem which may take hours or days for someone like me who is new to the program. Thanks..!!
I am trying to model a multi-stage riser structure for a detention pond. I need to input 2 orifices and 1 weir which all drain to a barrel (primary outlet pipe of the pond). So I put in a barrel pipe as a culvert and connected it from the pond to an outfall. Now when I try to put orifices, I can not connect them to the culvert (barrel pipe). And if I try to connect the orifices directly to the outfall (thinking that the software will know that it is going through the barrel pipe), the program gives me an error saying that more than one inlets to an outfall is not acceptable. Any solutions as to how I can model this in SSA?
KD
7 REPLIES 7
Message 2 of 8
Matt.Anderson
in reply to: kdave
KD -
You will need to have your 2 orfices, and 1 wier connected to a Junction.  That junction then connects your outfall barrel to the outlet.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 3 of 8
kdave
in reply to: Matt.Anderson
Thanks.
One more question. I want to put in a Broad Crest Weir but I don't see that option in weir type. Any suggestions?
Message 4 of 8
wfberry
in reply to: kdave
When you click on the down arrow next to Weir Type, Broad Crested is the very most top one.
Bill
Message 5 of 8
kdave
in reply to: wfberry
Bill,
I don't see it for some reason. When I click on the down arrow on weir type, here is what I get,
Message 6 of 8
kdave
in reply to: kdave
Sorry the screen shot image didn't show up as good as I thought it would. I have attached the file with this message.
Message 7 of 8
Matt_Haokip
in reply to: kdave
Hi kdave,
Although SSA does not list Broad Crested Weir in the dropdown list for the weir Types, you can account for Broad Crested Weir by defining the Physical Properties and Discharge Coefficient. The range for the Discharge Coeff. can be obtained by clicking on the ellipsis button next to Discharge Coeff.
Please see the attached image for reference.
Thanks.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
Message 8 of 8
kdave
in reply to: Matt_Haokip
Thanks a lot! That answers my question!
KD
Rail Community
