• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D - Stormwater
    kdave
    Multi-stage Riser
    314 Views, 7 Replies
    09-14-2011 07:30 AM
    First of all, I want to say that this discussion group has been very helpful. Thanks to Matt who responds quickly and solves the problem which may take hours or days for someone like me who is new to the program. Thanks..!!
    I am trying to model a multi-stage riser structure for a detention pond. I need to input 2 orifices and 1 weir which all drain to a barrel (primary outlet pipe of the pond). So I put in a barrel pipe as a culvert and connected it from the pond to an outfall. Now when I try to put orifices, I can not connect them to the culvert (barrel pipe). And if I try to connect the orifices directly to the outfall (thinking that the software will know that it is going through the barrel pipe), the program gives me an error saying that more than one inlets to an outfall is not acceptable. Any solutions as to how I can model this in SSA?
    KD
    Please use plain text.
    Employee
    Matt.Anderson
    Re: Multi-stage Riser
    09-14-2011 07:48 AM in reply to: kdave
    KD -
    You will need to have your 2 orfices, and 1 wier connected to a Junction.  That junction then connects your outfall barrel to the outlet.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    kdave
    09-14-2011 08:14 AM in reply to: Matt.Anderson
    Thanks.
    One more question. I want to put in a Broad Crest Weir but I don't see that option in weir type. Any suggestions?
    *Expert Elite*
    09-15-2011 11:37 AM in reply to: kdave
    When you click on the down arrow next to Weir Type, Broad Crested is the very most top one.
    Bill
    kdave
    09-15-2011 11:45 AM in reply to: wfberry
    Bill,
    I don't see it for some reason. When I click on the down arrow on weir type, here is what I get,
    kdave
    09-15-2011 11:48 AM in reply to: kdave
    Sorry the screen shot image didn't show up as good as I thought it would. I have attached the file with this message.
    Product Support
    Matt_Haokip
    09-16-2011 10:49 AM in reply to: kdave
    Hi kdave,
    Although SSA does not list Broad Crested Weir in the dropdown list for the weir Types, you can account for Broad Crested Weir by defining the Physical Properties and Discharge Coefficient. The range for the Discharge Coeff. can be obtained by clicking on the ellipsis button next to Discharge Coeff.
    Please see the attached image for reference.
    Thanks.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Mangkhothang (Matt) Haokip
    Product Support Specialist
    Autodesk, Inc.
    kdave
    09-16-2011 11:27 AM in reply to: Matt_Haokip
    Thanks a lot! That answers my question!
    KD
